Hello,
I just recently put in a new motor, sig has the details, but I also did the mass air conversion on my 86 notch. WHen I fire it up when it is cold it really idles low and surges bad, but once it warms up it seems to be better, not perfect but better. I checked all of the vacuum hoses and they are all tight and new now. One thing I did add was a C&L 73mm mass air sensor, the number on the sensor itself is F4SF-12579-AA not sure if that matters. The Emissions stuff has all been removed. I have cleaned the throttle body, IAC, and put a new TPS on the car. New plugs and wires. When running it really smells like gas. I do not have a adjustable fuel pressure reg. or a bigger than stock fuel pump yet. I have driven it on the street and it runs fine, very strong actually. All the plugs seem to be burning fine. I have sprayed carb cleaner around the intake and it doesn't upset the idle. I am lost.
HELP! The car only has 2 miles on it since the conversion.
