1. Wrap the end VERY tight 2-3 times around with electrical tape.
2. Take a dremel tool with a die-grinder composite wheel (mini chop-saw)
- this makes a very clean, no frey edge.
3. Push the hose to the bottom of where the threads begin inside the hose sleeve.
- Once just inside turn it as if you are screwing it on.
- leave excess tape on braided lines as a visual reference
- ensure no SS wires interfere with threads or inside of hose.
4. Place HOSE in the vise very close to Hose sleeve.
5. Oil the male end the pushes into the hose
6. BY HAND get the connector started in the threads.
- the force of pushing into the hose is working aginst the vise = no slip
7. Once started get the 11/16 and 3/4 wrenhes and tighten up to their specs.
It takes me longer to tape and cut than it does to actually build the fitting. In addition, I think -6 or -8s are easier than -4 or -3. (Same material, smaller hole...same size hands
For me the critical part is getting a smooth, straight and SS hairless hose end to start the process. After a couple different trys I found the dremel to be the easiest, best and cheapest tool for the job.
