safe RPM's
townethug
May 17, 2004
124
I am just trying to get a gauge as to what a everyone is rev their cars to. I plan on adding a 331 stroker at some point even though this summer I am just aiming for an H/C/I combo. Since the rpm range is important in picking out intakes it would be helpful to have some knowledge on the subject. So I guess the question is what is a safe number to rev to with out destroying my block, and what sort of things should I do to better prepare the block for the upper rpm's? This more of a weekend drive, not a whole lot of racing being done. Sorry if this is a newb question, didnt really see what I was looking for with searches.
It's not the block that limits the amount of revolutions (per-say.) More of it has to do with the balance of the rotating assembly and the mass of the parts. The pistions and rods need to be matched in pairs so they don't vibrate to pieces when you spin the motor over 6,500 RPM's. Also, the entire mass of things swinging around in there has a lot to do with it... The heavier the parts, the slower things will rev. Having the block blueprinted just means that all of the openings and bearing areas are measured. maybe if they find something out of tolerance the machine shop will fix it... But that is only if it's out of spec.
Also, if you plan on a high reving motor you should invest in a good balancer.
Most people though, keep their motors under the factory RPM limiter of 6,250 since they don't have the computer software to reprogram it. Also, it's hard to give you a range in where to shift your combo since every motor / car is different and it will really depend on the finished product. Personally, I have taken my car up to 7,000 on stock tach and not bounced off the limiter so I wouldn't even be able to tell you a good number to shift at since the factory gauges are more for looks than anything.
With any of the H/C/I combinations available, I believe the maximum you'd end up revving is around 6500 RPM. At that engine speed, your block would be perfectly fine. You'll probably come across many other factors that will limit your total RPM, long before you get into the block splitting territory. With a stock rotating assembly, you'd probably lose a rod before you ever damaged the block, but with the 331, you could take it much higher if it were properly balanced, and used quality parts. As far as valvetrain goes, you'd need some high dollar parts (solid roller cam, shaft mounted rockers, etc) before you took it high enough to really ever worry about the block being the weakest link in your typical run of the mill H/C/I build.
Also, I forgot to add....
The stock 5.0L block splits based on horsepower output (Torque really.) It usually happens right down the middle of the lifter valley. That general threashold is 450RWHP. You should keep total power output to around 400HP to be safe.
I wasnt actually planning on building a high reving motor, I was more concerned with taking rpm's over the reline on the stock tach, which is just under 6k i think. The parts I would need to support a 331 say the power range is from 1500 - 6500. I just didnt want to build a build a motor that is making its peak power higher then the engine should be running. I would hope that peak power is going to be somewhere between 5-6k. I know that wont be a problem with just H/C/I but when I add a stroker on I am not really sure what that is going to do with my torque/power curve. But it sounds like what I am hearing is reving over 6k normally doesnt pose any sort of threat.
Thanks alot, but since we are on the topic of cam shafts, is there anyone with a nice cam but is still emissions legal? Looking into comp cams but I thought someone that is pleased/disappointed with there cam could shed some light.
I have comp cam XE270HR-14 it has 512 lift, advertised duration, 270-276, at 0.050 218-224 I'm pleased with this cam other then it's a little dead up to 3000rpms and then it just spins the tires unless they are hot. My intake may be holding back a little until the rpms build up, not sure but it runs real strong on the top end
Hmm, I would like to feel alittle more power before 3k but its not a huge issue, would going to 1.7 rockers help? Also you didnt mention if it passed emissions. Also since i am new to the whole cam thing, I would have to replace my rockers if i switch to one of those "xtreme energy" cams anyway wouldnt I?
