Safe ShoT???
Guero
2,148
Whats a safe shot i can run on nitro? with 1 degree colder plugs set at stock gapping, and at 14 degree timimg. member i can adjust my fuel now, 255 lph pump, 30lbs injetors. heads and cam
You will want to turn down the timing to around 9-10*. You also may run into a spark blow out at higher rpm with the stock gap on the plugs.
The only way I would run 14* without a sep. tune to switch to for n2o would be to use a msd digital6+ or something like that having the ability to retard timing when the n2o is activated. This way you could run 14* off the bottle and 9-10* while spraying.
im gonna do a 75 shot, since its only like 60 on the zex kit. and i will retard the timing to, i know i mentioned i was at 14 but didn't mention i would go back down to stock on the spray
