Safe to cap off the a/c and s/c vacuum lines?
94GTNJ
94
I removed my A/C and I never use cruise control (gonna ditch that too) is it safe to cap off those two vacuum lines and remove them? Just doing it to clean up the engine compartment. Thanks
Capping the small A/C line will mean that you get no vacuum to your Heater-A/C controls in your cabin. If you only need Defrost (the default postion) or none at all (race car), then this is fine.
If you would like to blow air to your body (Vent) or feet (Floor), leave it on. It goes over to a 3-way check valve that splits to the vacuum reservoir in the passenger fender and into the cabin.
If theres a certain vacuum line you removed from some a/c component, then you must cap that part off. Everything else will work fine. Seriously, there is "ONE" vacuum line that comes from the inside of the car thry the firewall. Make sure this is connected to vacuum from the intake. This is the line that lets you change from vent to defrost and feet, etc.
