- Jan 10, 2009
- 28
- 0
- 0
I recently installed the saleen suspension kit on my car, then I had Les Schwab align the car. Once they brought it back close to factory specs there was a noticeable negative camber on the front wheels. They tell me I need camber plates, which they say cost 345 for the set, but I talked to some other tire buddies of mine and they say that '07 mustangs and up changed the struts so that all is needed is a set of camber bolts. Can anyone verify this?
If it is just camber bolts, which bolt slot am I supposed to install them in, the top or bottom? Thanks for the help....i recently bought a new set of tires, so i'm trying to fix this thing before my tires get too worn and the car stays pulling to the right regardless of a proper alignment.
What should I do?
What should I do?
