Saving gas tips?
unistork
25
It seems that I have to re-fill my gas tank every 50 miles (from half tank) and I only put in $10 worth so it only goes to about half tank. Any tips on how to save gas?
ACTUALLY, higher speed doesn't always constitute less gas mileage. For example, my car has a MPG guage. I get better MPG doing 70 or 80 than I do going 45 or 65. You can see the difference.
Usually does a light come on notifying you when you're low on gas that allows you to go at least 10 more miles before it runs completely out? That way you only fill up the tank when you really need too.
And I guess I burn my own gas because I change to 2nd gear before redline at around 6000 RPM lol, also, does it save more while driving in a low gear or high gear? for example if you're in 4th gear at 3500 RPM will that be better than being in 5th gear at 2000?
