Saw a post about 12v sources and hae a question
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Is it ok for me to tap into the 12v key on source on my mass air harness to turn on my alt. As most of you know the 3g requires a seperate 12v on source and i wanted to know if this would be an ok spot?
What happened to the stock alt wiring?
That will work OK, but you might want to add a a 1 or 2 amp inline fuse between the green regulator wire and the power source.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
