  • 1994 - 1995 Specific Tech
Scan said code 542???
  • Thread starter Thread starter Threeotwo94
  • Start date Start date Sep 16, 2005
T
Threeotwo94
38
Hamilton, New Jersey
Sep 16, 2005
  • Sep 16, 2005
Hey guys. Took my car to work and had one of the techs scan my car for any hidden codes since it was running really crappy. He did, and the scanner gave me 542. It said..."ECT to fuel pump ground" Something like that.
Any suggestions. Should i take it to FORD or should i search for this gremlin on my own?
Has this happened to anyone else?
And ive also done a search to see but couldnt find any info that was along the same lines as my problem....Thanks
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 16, 2005
  • Sep 16, 2005
That codes says fuel pump circuit open, PCM to ground.
what that means is that the computer detected a state in which the fuel pump was either:
1) not passing power through it.
2) The positive wire was disconnected
3) The ground wire was disconnected.
But I have also heard of these codes refered to as "ghost codes", which means there really isn't a problem, but for whatever reason, the code was stored.
What you need to do is get a paper clip and jumper the SIG RTN to the STI, turn the key to start the code flashing sequence, and then pull the paper clip. Pulling the paper clip during code readout clears the codes in the computer. Then go for a test drive and drive it for 10 miles. Re-read the codes, and see if it's there. If it's not there, then forget the 542 code and start from scratch.
Basics, check plugs/wires/cap/rotor, fuel pressure, vacuum, base timing, clean MAF & IAT sensors, & check the ECT sensor. That should keep you busy. But as far as order of ops, you should start with fuel pressure, then clean your MAF/IAT sensors, then the rest.
Scott
RIO5.0
6,892
N.H.
Sep 16, 2005
  • Sep 16, 2005
Mo...now that you mention "ghost codes"...mine pulled a 212 couple wks ago...but yet the car runs fine...
212 C Ignition module circuit failure/SPOUT circuit grounded
I pulled a 334 also for the EGR...but I deleted that and have the plunger set...that makes sense??
334 O,C,R EGR valve position sensor voltage above closed limit
T
Threeotwo94
38
Sep 17, 2005
  • Sep 17, 2005
Thanks Mo, I checks cap/rotor/spark plugs. Cleaned my Maf, not the IAC.
Probably going to get a FP gauge soon. As for the other stuff ill have to check it out.
Thanks again.
2001 GT stuck in 2nd
  • 01gtslider
  • Jul 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
01gtslider
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
Electrical Ecu wont read codes
  • 5.0ed
  • Jul 17, 2024
Fox 5.0 Mustang Tech Jul 17, 2024
5.0ed
