ScanTool question...
MatteMan
72
Sweden, Skövde
I have bought a obd2 reader and been using ScanTool.net software.
And my question is, when I looking at the 02 sensors it only showing two of the four sensors? Why is that, is it possible that two of them ar broken? Because I have problem whit the exhaust emission here in Sweden, on my car it´s only two catalytic converters. Either the catalytic converters are empty or some of the 02 sensor are broken?
02 Sensor 1 Bank 1 is swing between 0.095 - 0.885 V
02 Sensor 2 Bank1 is just swinging between 0.070 - 0.280 V ...Broken?
i don't see any problem. i see read outs for sensors 1 & 2 bank one and sensors 1 & 2 bank two. remember, there is no sensor 3 and 4. it's one and two or upstream and downstream for each bank
Ok thanks, so sensor 1 and 2 "bank 1" is in other words the 2 sensors in front of the catalytic converter? (upstream) and sensor 1 and 2 "bank 2" the 2 sensors behinde the catalytic converters. (downstream) Pleas correct me if I´m wrong.
Then it´s not a problem with them I think, so it has to be my catalytic converters that is the problem for the high exhaust emmision.
you want to make sure the upstream 02 sensors switch back and forth from low voltage to a higher voltage, and the rear 02's take longer to get a reading becuase they take longer to warm up. but after they do they should not switch with the front sensors. you should see a somewhat steady voltage from them. if you see sensor 1+2 switching just about the same amount then the cat converter is bad.
