Scheduled a dyno session!
WhiteDevil
2,717
San Diego
I am pretty excited. I have two hours on the dynojet scheduled for july 31st. The numbers in my sig were just two pulls with 32 degrees timing and a little too lean A/F ratio when the engine had only 900miles on it. Its got 7,000 on it now and I now also have 1 3/4 long tubes. WIth this combo i would be happy with 335rwhp. I hope with some playing with the A/F ratio and timing i can get there. I may also do some comparison pulls between the C&L tube and my Anderson power pipe. SO that should be fun too. I am so excited!
Have fun John :D
It will be interesting to see what that combo likes.
I'd think 32 is not enough ... but ... you will see :nice:
I'd go there and baseline at 34 and 12.75
I've seen some Aluminum head combos go as high as 38
Wait ... I seem to recall you be a Calif dude ... ;)
Ya'll aint got 93 grade gas ... do ya :bang:
If you only got 91 ... maybe start at 32
How high have you gone in your tuning John :shrug:
Grady
Well on the dyno run that made 327rwhp and 356rwtq i was at 32 degrees timing and the A/f was average around 13.4:1 slightly moving around. After the run i richened it up to 12.75 and now with my wideband i can monitor it. So as of right now with my PLX i see between 12.6-13 and am running 32degrees total timing.
Sounds like you are setup for a good place to start :)
If you can ... have each pull gathering data for later research :nice:
and
You can compare your wb readings against the shops wb readings ;)
Grady
