School me on Caster/Camber Plates
  • Thread starter Thread starter HaynStang
  • Start date Start date Feb 18, 2007
H
HaynStang
124
Portland
Feb 18, 2007
  • Feb 18, 2007
I thought I had been getting away with running my lowered stang without CC plates, but apparently not... I just noticed that the inside edge of my front tires have been wearing like crazy. If I don't do something my front tires are going to be ruined.
So I know I need c/c plates, but I have no idea which ones to go with. This car is my daily driver and sees 10-15k miles a year. Am I going to have signifigantly more noise, vibration or harshness with c/c plates using a spherical bearing versus ones with polyurethane bushings? How long do those bearings tend to last on street cars?
Who even makes a reasonably priced c/c plate with poly bushings... BBK maybe? The Hotchkis ones are way out of my budget. I need to stay under $180 but hopefully cheaper.
If c/c plates with spherical bearings would be fine for my application, then which ones should I go with? I know everyone loves the MM plates, but are they really worth the extra money, or are you just paying for the name? Is there something cheaper that will work just as good? The UPR steel plates are only $120... are they any good? Or Mac/Pro3i/Summit/etc for around $150 or so?
L
lxarlo
21
  • Feb 18, 2007
HaynStang said:
Well, I thought I had been getting away with running my lowered 'stang without CC plates, but I was wrong. I was under the car the other day and noticed the inside edge of my front tires are wearing like crazy. The driver's side is particularily bad and if I don't do something my front tires are going to be ruined.
if you want to go as cheap as possible, then have the alignment shop elongate out the stock shock tower holes as long as your negative camber isnt too extreme.
shhak
109
  • Feb 18, 2007
I just got my MM 4 bolt plates installed and I don't hear any noise from the spherical bearings. They may be a little more expensive but it's only a few extra bucks. Take into account the good looks and they are still well worth the money. However, I guess the UPR plates would work just as good. Just dont have the looks of the MM plates.
H
HaynStang
124
Portland
Feb 18, 2007
  • Feb 18, 2007
I'm kinda leaning towords the Pro3i's... isn't their stuff pretty much a close copy of MM's designs? I'm a student so the $40 savings makes a big difference to me. Has anyone tried the Pro3i plates?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 19, 2007
  • Feb 19, 2007
I got MM s for my car and I just shopped around until I got a good bargin.
H
HaynStang
124
Portland
Feb 19, 2007
  • Feb 19, 2007
How much did you find the MM's for Shakerhood, if you don't mind me asking? The cheapest I've found is $190. If I could find them for under $175 or so I guess I'd go for it.
f4fntm
88
Olympia, WA
Feb 19, 2007
  • Feb 19, 2007
lol - you don't buy MM stuff "for the name." It isn't Calvin Klein or or DKNY. Maximum Motorsports has the reputation they do because their stuff is strong and functions the way it should. They're grassroots racers who run what they build - a lot. Check out their website.
If you plan on keeping the car long, MaxMo is the way to go. After them, prolly Steeda is your best alternative. Both these outfits know their 'Stangs.
shhak
109
  • Feb 19, 2007
Not sure what year your stang is, but here's some MM plates for $190 with free shipping. http://cgi.ebay.com/ebaymotors/MAXI...013QQitemZ230092897631QQrdZ1QQsspagenameZWDVW
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 19, 2007
  • Feb 19, 2007
I got my MMs about a year and a half ago for like $165 Shipped.
J&M Products
Premium Sponsor
Jan 22, 2007
62
10
29
Paso Robles
Feb 20, 2007
#10
  • Feb 20, 2007
  • #10
We make the camber plates for Pro3i. We use only high quality parts in ours such as alloy steel main plates, Class 2 fit FK bearing which are heat treated chrome moly Teflon line bearings (with a lifetime guarantee), bearing cups are machined to a tolerance of +or- .0002", powder coated black. I can tell you that the overpriced name brand everybody talks about now uses the same powder coat company we do along with a lot of the same laser cutting companies and bearing suppliers. Good luck on your purchase.
jtfairlane
468
#11
  • Feb 20, 2007
  • #11
You're calling Maximum Motorsports an overpriced name brand? They could probably do the opposite and call you guys a no-name brand that simply rips off their designs. The "Professional Products" of suspension components.
MikeC
240
SLC, UT
Feb 21, 2007
#12
  • Feb 21, 2007
  • #12
That overpriced name brand has spent many years building a reputaion of making some of the best suspension parts in the aftermarket world. Can't beat the quality.
JChalfan
551
Bellevue, WA
Feb 21, 2007
#13
  • Feb 21, 2007
  • #13
I seem to remember paying about that for mine less than a year ago. If you look around, you can find good prices on them. I got mine online, but not from eBay. I looked through all my bookmarks and couldn't find the place I found them.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 21, 2007
#14
  • Feb 21, 2007
  • #14
Things to avoid:
CC plates made from aluminum in any form. They are weaker than a steel plate.
CC plates with a rubber bushing. The rubber bushing will delect under load.
Things to get:
CC plates made from high quality steel.
CC plates with lifetime warranty spherical bearings.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 21, 2007
#15
  • Feb 21, 2007
  • #15
I used some discount code on the Corral to get mine.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Feb 21, 2007
#16
  • Feb 21, 2007
  • #16
jrichker said:
Things to avoid:
Things to get:
damn...i have the wrong ones. probably doesnt help my nice front end shake at highway speeds. ive eliminated many...many things that couls cause it lol
JChalfan
551
Bellevue, WA
Feb 22, 2007
#17
  • Feb 22, 2007
  • #17
That sounds really familiar, I'm sure that's what I did also. If I remember right shipping took quite a while, but it was worth it for the savings.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
Suspension Caster Camber Main Plate Replacement
  • bleedinggreen
  • Apr 20, 2024
Fox 5.0 Mustang Tech Apr 20, 2024
bleedinggreen
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
