SCT MAF in a 3" pipe and meth injection?
jivepepper
776
Under a Sombrero. in WV.
Could I put my MAF in a 3" pipe from the 4" housing and still drive to the tuners?
Also I'm considering removing my SC and running water/meth injection as my only source of intake cooling. I want to free up as much restriction as possible and raise my octane at the same time. So I would need to put the bypass, MAF, injection nozzle, and the oat sensor all in the pipe between the head unit and throttle body. I heard if the bypass is to close to the the MAF it can cause drivability issue. How far past the MAF is to close to put the injection nozzle and how far in front of the iat sensor does it need to be for it to get an accurate reading. Also since I run a TFS intake with the oval TB upper it shortens the length between the SC and TB.
Thanks for any help, or opinions.
