SD to MAF Conversion. Have Harness Need Help.
  • Thread starter Thread starter Manewaymja2
  • Start date Start date Apr 3, 2009
Manewaymja2
245
  • Apr 3, 2009
Hi there guys, I am in need of some advice, I have a Complete Wire Harness out of a 1993 MAF Mustang and trying to convert my 87 Stang to MAF. Well I dont want to strip my car to intasll a complete harness, so I was wondering if i could simply trace the MAF conector wires and unplug them off the 93 harmess and run them to my existing harnes and plug them in like with the Granatelli Harness i saw for sale?
I already have the Computer as well. If the above is possible is there any thing else i should know before i do this. Maybe a diagram on the placement of the pins could help me to.
Thanks Matt
strtrcr50
Previously from Dirty Jerzey exit 7a
Apr 3, 2009
  • Apr 3, 2009
MAF - Mustang Mass Air Conversion - StangNet - The Mustang Network
Manewaymja2
245
  • Apr 3, 2009
need to know which wires are being refered to in that article i have a red, black, blue/orange and a orange/blue.
a. The Power (+) wire from the MAF meter harness needs to be spliced into the existing red wire in position #37 of the EEC connector.
b. The Ground (-) wire from the MAF meter harness needs to be spliced into the existing black/green wire in position #40 or #60 of the EEC connector.
c. The Signal (-) wire from the MAF meter harness needs an EEC pin which then gets inserted into position #9 of the EEC connector.
d. The Signal (+) wire from the MAF meter harness needs an EEC pin which then gets inserted into position #50 of the EEC connector.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 3, 2009
  • Apr 3, 2009
The MAF connections do not exist in the 87 harness. You will need to add wires with pins to make it work.
See Ford Fuel Injection EEC Connector for some help with removing and installing the wires and their connector pins.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
