seal question
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jun 29, 2008
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 29, 2008
  • Jun 29, 2008
On a 93 5.0 is there a seal on the front of the engine like the rear main seal? If so whats involved in replaceing it? Do i need to pull the oil pan? Is it a press in type seal like the rear main is? peace
john
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Jun 29, 2008
  • Jun 29, 2008
the one the crank snout comes through? or the one under the timing cover? if its the one the snout comes through just get a flat haed screw driver and pry it out. then use a hammer and a small block of wood to pres the new on on.
if its the one under the timing cover you have to remove the timing cover.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 29, 2008
  • Jun 29, 2008
i'm not sure witch one it is? i will replace them both. i caint remember do i need to drop the oil pan to remove the timming cover? peace
john
LiquidGT
368
Near STL hell
Jun 29, 2008
  • Jun 29, 2008
The seal under the timing cover is the oil pan gasket. For the crank seal you have to take off the timing cover to remove and press in the seal.
No you dont need to drop the oil pan, just the first four bolts on the oil pan that holds the TC. And be careful when you take out the TC because the oil pan gasket can rip, and this could be bad if you have the 1-peice gasket, then you would have to drop the pan or use RTV.
V
v8only
2,378
22
49
Jun 30, 2008
  • Jun 30, 2008
there is actually a specific seal that goes around the snout that the harmonic balancer rides on. it's in the timing cover itself. I think you have to pull the timing cover to replace it, but memory doesn't serve me here. If you do, I'd replace the oil pan gasket too...the one piece felpro unit works best.
it would be easiest to yank your drivetrain out for this work
ShortThrow50
923
Pa
Jun 30, 2008
  • Jun 30, 2008
i would yank the whole engine and change all the gaskets. front seal, rear main, and the oil pan. thats just me though lol
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 30, 2008
  • Jun 30, 2008
it's got a brand new rear main and fel pro 1 piece oil pan gasket. i was hoping not tohave to pull the pan! It hardly drips i'd say 6 or so drips when it sits for like 3 months. but i do get some light splatter on the fenders between oil changes. if i have to pull the motor i'm doing it when i drop the 351 in. just courious if i could change it like a rear main? peace
john
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
F
Leak from tail shaft after 2 new seals
  • Fox123
  • Aug 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 9, 2026
JD1964
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
