Sealing Fuel Sending unit
  • Thread starter Thread starter Rjovi
  • Start date Start date Jun 9, 2009
R
Rjovi
44
Co
Jun 9, 2009
  • Jun 9, 2009
Twice now I have installed the sending unit with a new ring and it leaks. When I took it out it had some kind of putty looking stuff around it, does anyone know what this is or where to get it? Thanks
'65 if it matters.
tx65coupe
Jun 9, 2009
  • Jun 9, 2009
There is supposed to be a rubber O ring in there as well. Did you put it back together with a new O ring or a new lock ring?
R
Rjovi
44
Co
Jun 9, 2009
  • Jun 9, 2009
yeah, sorry I wasn't clear. I twice replaced the O ring. The first one I got was a rubber o ring so I thought it leaked because it was junk. The next one I got was like the original, kinda square and thick, but I still have a drip.
golf4283
1,253
Orland Park, Illinois
Jun 9, 2009
  • Jun 9, 2009
Here's what to do.
Take out the fuel sending unit and clean the flange that the ring sits in with some rubbing alcohol or other spirits. Next thing you do is take a pliers and slightly crimp each of the three mounting tabs on the fuel tank itself.
Next thing remount the fuel sending unit with the proper o-ring and twist the lock into the proper place. Finally take a flat edge screwdriver and hammer the lock tabs down so the ring doesn't slip.
I had leakage in my tank and I did this on Saturday. Hasn't leaked a drop since. You just want to make sure that it's tightening enough to keep even pressure on the ring.
Sometimes with these cars you just gotta be creative and think of a solution. with a 40+ year old car sometimes it's not as straightforward.
brianj5600
1,964
Middle TN
Jun 9, 2009
  • Jun 9, 2009
I vasolined my o-ring and it seemed to go together good. Mine was all new parts so that helped I'm sure.
golf4283
1,253
Jun 9, 2009
  • Jun 9, 2009
I've heard that method too but I didn't have any vasoline around so I just worked with what I had.
R
Rjovi
44
Co
Jun 9, 2009
  • Jun 9, 2009
hmmm, vasoline...brillliant I'll do all the above, thanks guys
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 9, 2009
  • Jun 9, 2009
Agreed--it has worked good for me too.
dennis112
1,561
36
79
Jun 9, 2009
  • Jun 9, 2009
I agree that you must lube the O ring and Vasoline works well on them.
HookandLadder
261
St Louis
Jun 9, 2009
#10
  • Jun 9, 2009
  • #10
Vasoline. And it helps keep it in place while you get the lock ring on. No steel...sparks. Brass drifts only please.
RGS0907
429
New Jersey
Jun 10, 2009
#11
  • Jun 10, 2009
  • #11
'65 if it matters.
I had an aftermarket sending unit where the fuel was dripping out of the post for the gas guage wire, nothing I did would stop the leak. I ended up tossing it and rebuilding my stock one.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Saturday at 7:48 PM
AlexM556
A
M
2000 mustang fuel feed tube
  • Mali
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2026
Mali
M
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
