Seat Cushion has worn down, need ford replacement part. Where can i order
BigChiefSmokem
1,400
Jacksonville, FL
So my drivers side seat cushion under the leather has worn down so much on the side facing the door that the steel seat frame is poking me in the leg and messing up the leather. THeres literally a steel bar poking me there. Its painfull, and i'm out of warranty.
So, where can i order the factory seat cushion, and how hard would it be to fix?
well, we can get them. I would need either your vin # or a trim code off the certification label on the driverside door jamb. I can tell you it won't be cheap.
What kind of foam and where did you get it?
standard foam
all i did was cut some strips and push enough in till it was even with the other side
