Selenoid sparking
  • Thread starter Thread starter 66overhaul
  • Start date Start date Feb 22, 2007
66overhaul
22
  • Feb 22, 2007
Hi:
I recently (early fall) put in a new wire harness and starter selenoid (plus other things) and everything seemed fine. I then let my 1966 (289) mustang sit through most of the winter. When I went to start it the battery was too weak, so I charged it. When I then went to start it i got a large spark (slmost a flame) from the selenoid, where it is connected to the battery. Each time I start it I now get sparks at that point and the + battery cable is very hot. Any ideas?
Thanks,
66overhaul
Iamdiffrnt
197
South of Detroit, MI
Feb 22, 2007
  • Feb 22, 2007
Sounds to me like either a bad solenoid, a loose connection in the battery cable to the solenoid, or something is getting grounded there.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Feb 22, 2007
  • Feb 22, 2007
Agreed.
I would first check the cables and if that didn't do it, replace the solenoid again. Not to insult your intelligence, but are you attaching the + cable to the + on the battery (and vice versa.) Just had to ask.
Another thing you could try is to remove the large wire off the rear of the solenoid (that goes down to the starter) and then turning the key to see what happens in the "start" position. Of course it is not going to start but it might be a better indication of where to look for the problem.
Boss.Hoss.Ross
29
Petoskey, MI / Big Rapids, MI
Feb 22, 2007
  • Feb 22, 2007
x2 for the bad connection at the battery! sparks=bad connection, heat=high resistance=bad connection.
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Feb 23, 2007
  • Feb 23, 2007
I've experienced that spark before. What caused it was either a bad starter, or the cable that goes down to the starter touching the header.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
