Self Test Timing Advance Problem...
Need Help ...Please!!!
I have an 87 Mustang GT with the H.O 5.0. I ran a self test diagnostic on it and noticed that when I had started the car the engine timing didn't advance like it should. Instead the my car made this loud sucking noise like you get when you have a cold air intake on and hit the gas. Then the idle got a little rough and then it just ran like normal again. Any suggestions on what to check out for this would be appreciated greatly. Thanks
That's exactly what it is supposed to do. The running self test opens the EGR valve at idle, which makes the engine cough and run rough. I recommend that you get a Chilton's shop manual to get all the info on running the tests.
