separating A/C Lines (see pic)
  • Thread starter Thread starter DonMaximo
  • Start date Start date Aug 27, 2007
D
DonMaximo
217
Lewisville, Texas
Aug 27, 2007
  • Aug 27, 2007
I've removed the clips which keep this A/C line together. However, they're not easy to pull apart.
Am I being limp wristed and need to just yank harder =or= is there something that I'm not doing right.
strtrcr50
Previously from Dirty Jerzey exit 7a
Aug 27, 2007
  • Aug 27, 2007
You need to leave the spring lock tools in there till they unhook..
88mouse
630
Mooresville nc
Aug 27, 2007
  • Aug 27, 2007
There is a tool that goes inside that fiting to push the spring that holds the fitting together. Then you can pull them apart.Will probly be pretty tight,so you will have to pull pretty hard.
D
DonMaximo
217
Lewisville, Texas
Aug 27, 2007
  • Aug 27, 2007
A/C Tool
I was able to remove the outside clips by hand. So I presume you're talking about a tool that fits the items in the picture I included.
Can this tool be purchased from a good Auto Part Store (NAPA/O'Reilly) ???
Or will I need to go online ?
Thanks again
Saleen0679
876
24
49
Yakima, WA
Aug 27, 2007
  • Aug 27, 2007
Those are the spring lock couplers. The tools that the guys are talking about are readily available at many auto parts stores. You don't want to just go yanking on those without the tools.
Flavadave4
1,044
21
49
Utica, NY
Aug 27, 2007
  • Aug 27, 2007
Mine came right off with the little tools that slide over the fitting.
cenok is family
1,409
69
79
Norman, Ok
Aug 27, 2007
  • Aug 27, 2007
yeah, they're the same as many a/c disconnects. autozone, oreilly's, pretty much any auto parts store has the tool you need.
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
