  • SN95 4.6L Mustang Tech
seperating tranny from engine
  • Thread starter Thread starter snidehockey
  • Start date Start date Jul 12, 2008
snidehockey
131
Orlando, Fl
Jul 12, 2008
  • Jul 12, 2008
I'm in the middle of tearing down the engine right now for a rebuild...
yesterday I unmounted the compressor, alternator, PS pump...drained all fluids, disattached almost all of the wiring (except some from the bottom.) dropped the X pipe etc.
Next up me and a buddy who has an engine hoist are yanking the engine and tranny (tranny is getting replaced)...
We attempted to lift the engine before but failed to break any of the bell housing bolts...we didn't put too much time into it because we weren't really too commited to the job...
we couldn't even break loose the drive shaft bolts (using air tools)...
Any tips for this? He proposed dropping the K member to lower the engine and tranny out as one piece but I'm not a fan of the idea...
N
neuf
37
  • Jul 12, 2008
Use lots of PB blaster or whatever you use, I let it sit over night. I eventually got it off with a torch and a hand wrench.
snidehockey
131
Orlando, Fl
Jul 12, 2008
  • Jul 12, 2008
OK, cool...and did you have to be a contortionist to get the bolts at the top of the bell housing or no?
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 12, 2008
  • Jul 12, 2008
drop the trans cross member and place a jack under the tail shaft. that will angle the trans down enough to get to the bell housing bolts.
unless you have a lift i would not drop it from the bottom. if you do have access to a lift it is MUCH easier to drop it from the bottom
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Engine compartment Detail tips and pointers...
  • CarMichael Angelo
  • Feb 19, 2019
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 26, 2019
Rdub6
Progress Thread Haven't posted in a looong time... rescuing another 'stang... '89 Vert
  • ChillPhatCat
  • May 20, 2019
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 1, 2023
joeballz83
J
Forced Induction New Engine And Turbo - First Start Questions
  • wiseguyk
  • Feb 1, 2018
  • 2 3
12K
Fox 5.0 Mustang Tech Sep 30, 2026
from6to8
