  • SN95 4.6L Mustang Tech
service engine light ?
  • Thread starter Thread starter mustangkid05
  • Start date Start date Jan 2, 2007
mustangkid05
199
  • Jan 2, 2007
i did the search but didnt get the specific answer
my service engine light been on for about 3 weeks & its because i just put an o/r h on and the mil eliminators i bought i guess they didnt work and the ? i am asking is
will it hurt my engine in anyway because the service engine light is on?
thanks alot:SNSign:
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 2, 2007
  • Jan 2, 2007
no it will be fine. mine has been on for a few months, i just ignore it. i will check it every week or so just to make sure its the catalyst inneficiency codes and not something else.
mustangkid05
199
  • Jan 2, 2007
oh ok cool thanks alot
fast97gt
1,082
north carolina
Jan 2, 2007
  • Jan 2, 2007
service engine light trouble
alright your check engine light is on for a catalyst insuf. correct, if it is then your comp. goes into limp mode (factory preset systems under normal driving conditions)anytime your check engine light comes on, so if your racing or trying to get peak performance out of you car its not gonna happen till you get it fixed. i know because i installed o/r x pipe no cats on my 97gt and the light come on and i couldnt get the dyno tunes until i got the mil elims. to get the light to go off.(oh by the way ive got a lot of experience with diagostic and tunning on 96 and newer cars
fast97gt
1,082
north carolina
Jan 2, 2007
  • Jan 2, 2007
alright your check engine light is on for a catalyst insuf. correct, if it is then your comp. goes into limp mode (factory preset systems under normal driving conditions)anytime your check engine light comes on, so if your racing or trying to get peak performance out of you car its not gonna happen till you get it fixed. i know because i installed o/r x pipe no cats on my 97gt and the light come on and i couldnt get the dyno tunes until i got the mil elims. to get the light to go off.(oh by the way ive got a lot of experience with diagostic and tunning on 96 and newer cars.
97gt
bbk true cold air kit, basani o/rx no cats, pro5.0 powertower shifter, 2 chamber flowmaster, 2.5in exhaust w/ dumps, 4.10s, 5speed, kingcobra clutch,underdrive pulleys, steeda cable quad. and adjuster, cobra nose and decklid w/ wing, more mods soon...
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jan 2, 2007
  • Jan 2, 2007
my 98 has not gone into limp mode. i had the light on when i did a high performance driving event at buttonwillow. about an hour and a half of on track time driving the living piss out of my car and no lost performance or drivability. i even had an AIX driver drive my car around the track and the only thing he noticed was the coilovers werent corner weighted properly.
mustangkid05
199
  • Jan 3, 2007
yea^^ it dont feel slower imo
D
Dragstr05
643
Stafford VA
Jan 3, 2007
  • Jan 3, 2007
I didnt think mine went into any type of limp mode either. Never really felt any different, and honestly I probably didnt notice it because the gain from the midpipe helped to offset the loss in power. Then a guy (master ford tech if I must add, races as well), told me that I needed to get MILs cause I was killing my power if I didnt. Sure enough when I got them in and the roads dried up enough after it had rained a few days and I could get on it, the difference was very evident in higher RPMs in 3rd/4th gear, and it was barking the tires harder.
fast97gt
1,082
north carolina
Jan 4, 2007
  • Jan 4, 2007
well i noticed on mine that when would shift at 5 5500 rpms my car would back fire the i got the mils put on and engine light off i dont do it no more so all im sayin is if your service engine light is on in your ride its NOT going to run efficiently
RedBullitt
462
Morgantown WV
Jan 4, 2007
#10
  • Jan 4, 2007
  • #10
pretty sure that cant make the car limp, could be wrong though. mine is always on and my afr stays the same with or without the light. also, cant feel any significant difference. Need some light on track times and light off track times haha
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jan 4, 2007
#11
  • Jan 4, 2007
  • #11
it will not go into a limp home mode..
Get the code checked and make sure it cat codes and then check your MIL elims.
fast97gt
1,082
north carolina
Jan 4, 2007
#12
  • Jan 4, 2007
  • #12
my god yall all about bustin someones balls, you wont notice a difference in hp cause its only like 12 to 18 youll lose. limp mode is a term that mechs. use to define that the car is not running efficiently, when sensors go bad the engine relys on factory settings that are factory stored and the comp. sends the sig. for the light to come on and the factory settings are as if your were driving the car like a sane person all the and we all know mustangs arent for sane people and are to be drivin like they were made to be drivin "fast and hard"
mustangkid05
199
#13
  • Jan 4, 2007
  • #13
^^ lol
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 4:37 PM
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
