Setting cold idle time in ECU
LaserSVT
3,548
233
How do I set cold idle duration in the ECU the cheapest way? Do I have to buy a programmer, custom burned chip, or is there something for my laptop I could get to do it?
Got my Cervini hood put on today, I LOVE it! I will take some pics with my phone and post them later.
The cheapest for a DIYer is to find the underlying reason for the issue. The OEM strategy should work just fine.
Different cam, throttle body, injectors, exaust, no emmisions stuff, larger pistons.
It just needs a few more seconds on the cold idle. Those would be the underlying reasons mabey:shrug: If it was 20-30 sec longer it would put enough heat into the engine to idle smoother once it is off cold idle.
If you are having drivability issues, and no codes are present...
(You have pulled the codes, haven't you?)
Then a custom tune is the next step.
Option include products like
TwEECer & TwEECer RT
MOATES.net
PMS
and a variety of standalones.
Without a J3 tuner (Moates/Tweecer) you cannot change the time that the ecu spends in cold OL.
The PMS may have a way to lengthen the time in warmup, but I'm not sure. I have had a hard time getting details on how the PMS actually works...
Standalones will allow you to do almost anything you can dream up.
Generally speaking...
Cheapest to most expensive
Moates - tweecer RT - PMS - Standalone
Add a WB O2 to any of these setups and you can do a lot of powerful stuff with SEFI.
I would encourage the Moates or tweecer RT. They are extremely cost effective, and offer far more functionality than most folks will ever need.
Let us know what you go with,
jason
EDIT:
How about some more detailed info on the chages you have made?
MOATES.net
PMS
jason
EDIT:
where can I get info on the tweecer and moates?
