setting time
  • Thread starter Thread starter fox04
  • Start date Start date Mar 15, 2012
fox04
78
augusta, ga
Mar 15, 2012
  • Mar 15, 2012
Ok I started my h/c/I swap an before I started I wasn't thinking and just pulled the distributor out instead of putting it on tdc an just putting it straight back in. When I'm do e with my install should I just turn the motor so no1 is tdc an slide the distributor in? Or how should I go abt doing it. With spout connector in or out?
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Mar 15, 2012
  • Mar 15, 2012
Yes, put #1 on TDC compression stroke, then line rotor up with #1 plug wire. Rotor should be pointing somewhere directly back towards the intake. You will probably have to leave the dizzy a little loose and have someone slowly rotate it while you are cranking in order to get it to fire. Jrichker and some others have write ups on here that are more detailed if you can do a search.
Joe
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
  • dan50
  • Jul 18, 2026
dan50
