setting valve lash...
  • Thread starter Thread starter browell_66
  • Start date Start date Apr 27, 2009
browell_66
14
South Ga
Apr 27, 2009
  • Apr 27, 2009
It's been a while since i've had an engine with hydraulic lifters. What's the best way to set valve lash? This is a flat tappet cam. Thanks.
R.J.
813
Warwick, Rhode Island
Apr 27, 2009
  • Apr 27, 2009
This method of adjusting rockers will guarantee that the cam lobe of the cylinder that is being adjusted is at its lowest point.
With the piston at TDC, with both valves in the closed position, do the following:
The first thing you want to do is verify zero valve lash. The best way to do this is to wiggle the push rod up & down as you tighten the rocker arm nut. At the point where the push rod no longer moves up & down, That is zero lash. You now have a starting point for verifying “true” zero lash & the lifter pre-load.
When you adjust the valves you are setting the lifter pre-load, Pre-load is the amount of distance the push rod seat (or “cup”) moves away from the retaining clip.
To set true zero lash & the lifter pre-load, We are going to follow the “EO / IC” procedure.
What is “EO / IC?
EO, is Exhaust Opening; IC, is Intake Closing.
We have the piston at TDC (Both valves are in the closed position), Rotate the engine in the normal direction of rotation (clockwise, if you are facing the front of the engine).
You will see the exhaust valve just starting to open, stop rotating the engine & back off the intake rocker arm.(You are going to back off the rocker arm & re-verify for true zero lash, As you are now positively on the base circle of the camshaft whereas the previous lash adjustment was just a pretty close ballpark guess.) You will once again wiggle the push rod up & down as you tighten the rocker arm nut. When all up & down movement is gone, tighten the rocker arm nut ½ turn, tighten the hex head set screw until it bottoms out on the rocker stud, tighten the rocker arm nut ¼ additional turn. You have now set the lifter pre-load at .045”.
Rotate the engine, You will see the exhaust valve fully open & then close. Watching the intake valve that you just set, You will see it open, You want to keep rotating the engine until it fully opens & then starts to close. When it is almost closed, stop rotating the engine. Set the exhaust valve the same way you did the intake valve.
Move onto the next cylinder in the firing order…
browell_66
14
South Ga
Apr 29, 2009
  • Apr 29, 2009
Thanks for the info....
D
Early ford 302 heads
  • Dagasser
  • May 4, 2026
  • The Welcome Wagon
The Welcome Wagon May 4, 2026
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
