Settle at last: Hooker comps or supercomps?
  • Thread starter Thread starter stangman67
  • Start date Start date Nov 30, 2005
stangman67
294
connecticut
Nov 30, 2005
  • Nov 30, 2005
After reading for quite a while, I'd like people with experiece to tell me which way to go. There is a nearby powdercoating shop, so either header will be uncoated. That way i can ding them to fit, then make them look nice. I have a 289 with maybe 330-350 fwhp, and a t5 with modern driveline cable conversion. Which fits best? Which gives me the best all around performance? If the comps cost me 5-10 hp, I may not splurg for the super comps then. Please help me and alot of others out. Thanks.
jerry S
1,365
52.22N 5.12E
Dec 1, 2005
  • Dec 1, 2005
I believe they are identical except for the gauge of steel used. The Comps use 16 gauge steel (thicker and heavier) while the Super Comps use 18 gauge steel (thinner and lighter). I may be wrong but this is what the tech guy at Summit told me. For a street car, the comps are prolly just fine. As for powder coating, I opted for getting the ceramic coated comps because everyone told me the powder coating would not take the heat over time and would eventually deteriorate. I guess you could bash them into place and once assured of fitment, send them out to Jet Hot.
J
Jc69Stang
95
  • Dec 1, 2005
I would go with the comps for your combo.
But my Super Comps are 1 3/4" not 1 5/8" like the comps, so double check the pipe diamater to be sure. The comps will fit a little easier if this is the case as well.
jcode68
892
Massachussetts
Dec 1, 2005
  • Dec 1, 2005
You can check out this link from a fellow Stangnetter to see what combo's others are using if you haven't seen it yet:
http://www.stanginfo.com/Headers/headeroptions_view.php
I went through this decision myself recently for my 68 with fresh 347 (302 block) and T5 transmission, power steering. I decided on the Comps with ceramic finish and I'm glad I did. The fit is excellent, had to install the PS drop bracket but I didn't need to ding them at all. I decided to go with the JMC hydraulic clutch install to avoid the interference fit with the cable setup. I think others are running a setup similar to yours, but you should verify this. Here are some pics of my Comps installed:
W
Wubbasnake
14
Laplace, La.
Dec 2, 2005
  • Dec 2, 2005
I have the ceramic comps installed on my 65 f/b and couldn't use the cable setup.The way the headers come down there's just no room to get the cable in there. I had to go with the hyd. setup.
stangman67
294
connecticut
Dec 2, 2005
  • Dec 2, 2005
Hmm, thats not too good then. Do the supercomps fit the cable? Id rather not have to redo the clutch setup. Thanks for the replies.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Dec 3, 2005
  • Dec 3, 2005
I have actually heard that the supercomps work well with cable clutches. The reason being that it has an opening between the primaries and collectors making room for the cable to fit in between. Atleast this is what RMP, and modern driveline have said. There is also a certain hedman header that works well.
M
meganjoe
35
The Poconos
Dec 3, 2005
  • Dec 3, 2005
i have the comps jet hot coated on my 68 289 , no power steering, and cable actuated clutch ( t-5) ... i did wrap the cable but its not really that close...
J
  • JRC99
  • Apr 19, 2025
JRC99
J
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Progress Thread 88 Notched Fox
  • NotchedGarage
  • Jul 15, 2023
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2024
Flyboy60
F
Progress Thread 87' GT rescue
  • africansnowowl
  • Apr 29, 2020
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2020
Cheapskate207
SN95 Redoing My Exhaust
  • 02 281 GT
  • Mar 28, 2015
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2015
02 281 GT
