Does the vacuum line from the trans plug into the back of the intake manifold. I have a Edelbrock Torker I, It has one plug in the back that is tucked just below the carb.
Also what do you guys recomend for initial timing. 302 Bored .30 over, all accel 300+ ign, hooker comp headers, edelbrock torker intake, roller rockers, holley 650 double pumper.
Also where can i get a throttle bracket for the linkage, I have a C4.
Does ANYONE know where i can get some steel v-groove, serpentine with grooved water pump pulleys..(4 bolt balancer) The billet pulleys are way the hell to expensive.?.
What size wrench is it to bleed the front drum brakes 69 coupe. I don't have one that small and need to go buy one...?...
