  • 2005 - 2009 Specific Tech
Shaker Head Unit Wattage
  • Thread starter Thread starter RichSNJ
  • Start date Start date Dec 28, 2006
R
RichSNJ
  • Dec 28, 2006
I have been searching all of the net for this info for a really long time and I cant find a straight answer on the Shaker (500) Head Unit wattage output.
I would like to replace the main speakers and the head unit, but want to make sure that I get at least as much volume out of it that I get now. Most of the units I have looked at to replace the Shaker with are 22 watts RMS / 50 Peak per channel or 200 Watts Peak total. While I haven't been able to find any specs on the Shaker head unit itself, I DID find specs on the sub amps and I believe they are 120 watts peak / amp (~240 watts total) which leaves ~260 watts peak to the head unit or 65 watts per channel. I don't really believe that it actually puts out 260 watts, but there is enough doubt to delay any $$$ purchases until I get an answer from someone who knows...
I have heard lots of people say that everything sounds "better" after replacing the Shaker, but no one says its as loud. It probably doesn't matter as much with the coupe, but I've got a convertible, and when you are speeding down the freeway with the roof down, you need all the volume you can get.
Any info on these specs would be greatly appreciated...
stanmckinney
1,188
Dec 28, 2006
  • Dec 28, 2006
Mine sounds better and I would say it is just as loud if not louder. I don't believe you will have a problem.
like a G
Orlando, FL
Dec 28, 2006
  • Dec 28, 2006
http://media.ford.com/newsroom/feature_display.cfm?release=20248
Says the Shaker 500 is 500 Watts peak and the Shaker 1000 is 1000 Watts peak.
Hope that helps.
iskwezm
4,159
20
79
Rowland Heights,California
Dec 28, 2006
  • Dec 28, 2006
I replaced the head unit and replaced the amps and kept the stock speakers in my convertible and it sounds 100 times better with "less" power.I think the shakers are a waste of money and in got stuck with mine already on the car and ended up taking most of it out.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Run a 5 channel or use head unit and mono amp for sub?
  • 2000xp8
  • Sep 20, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 23, 2024
2000xp8
L
2003 New Edge Mach 460 question.
  • LightSkinMocha
  • Jul 6, 2023
2K
1996 - 2004 SN95 Mustang -General/Talk- Jul 27, 2023
Ranger
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Upgrade Advice on an 89 GT Convertible NJ
  • SteakDad
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 18, 2025
limp
