Shaking a bit!?
  • Thread starter Thread starter RedstangTF
  • Start date Start date Sep 3, 2007
R
RedstangTF
Yorktown, VA
Sep 3, 2007
  • Sep 3, 2007
got some vibration going on in the high rpm's whether in or out of gear.everything is jacobs electronics except for alternator and battery.think I have 1 bad spark plug but anything else?
88mouse
630
Mooresville nc
Sep 3, 2007
  • Sep 3, 2007
harmonic balancer is probable spun.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Sep 3, 2007
  • Sep 3, 2007
is it shaking at high speed and rpm's? or just at high rpm's in general?
jake2582
107
tallapoosa
Sep 3, 2007
  • Sep 3, 2007
mine was!
G
GaryB
24
Flordia
Sep 3, 2007
  • Sep 3, 2007
last time a ballancer spun on my lightning it was rough at idle and would smooth out at speed. just thought I would add that.
R
RedstangTF
Yorktown, VA
Sep 3, 2007
  • Sep 3, 2007
well it is kinda shaking at high speeds but i am in the process of braking in a new transmission so I can only assume I need to be easy on it for a while. Umm the Idle is the best thing about the car I could set a nickel on it. How could I go about checking the balancer?
cenok is family
1,409
69
79
Norman, Ok
Sep 3, 2007
  • Sep 3, 2007
i'm in the middle of the same thing, as far as breaking in a new tranny. i'm still breaking in my motor as well. i've noticed my car shakes pretty good when i get above about 70mph or have the rpm's above about 5k. i'm pretty sure my u-joints, actually my driveshaft in general, is the culprit on my car. when was the last time you checked your u-joints? as far as the balancer, there's an outer ring that is attached to the center of the balancer via a layer of rubber. over time that rubber dries/rotts and the outer ring can seperate from the rest of the balancer. inspect the rubber thoroughly. also, turn your car on and let it idle and look at the balancer for any wobbling.
R
RedstangTF
Yorktown, VA
Sep 3, 2007
  • Sep 3, 2007
Beautiful car btw. I have an alum driveshaft and its fairly new but the U-joints i dont think have been touched for a while, i recently accuired the car from my stepfather who only drove it on the track every now and then. they may be very old!!! I have searched through his reciept book and found nothing about what kind of U-joints should be used. any Ideas? and thanks will check balancer tonight.
G
GaryB
24
Flordia
Sep 3, 2007
  • Sep 3, 2007
the frpp aluminum drive shaft comes with new u jionts installed. look over the new transmission instalation, did this start when the transmission was installed. break in should not be an issue!
R
RedstangTF
Yorktown, VA
Sep 4, 2007
#10
  • Sep 4, 2007
  • #10
it started when I was having problems with charging system(battery and alternator) I made a mistake and replaced the coil with one that was not jacobs elec. and then changed the transmission. I have switched the coil back and gone through the seven step idle process, and still getting shaking at high rpms. speed does not seem to matter even in first after about 2250 rpm vibration comes through the firewall and shifter.
R
RedstangTF
Yorktown, VA
Sep 4, 2007
#11
  • Sep 4, 2007
  • #11
checked the rubber around the balancer and seems to be ok for the age of the car. and as far as the wobbling, a little at idle but then it smooths out i guess it is the balancer.
R
RedstangTF
Yorktown, VA
Sep 4, 2007
#12
  • Sep 4, 2007
  • #12
well thanks to all for the info. guess I'll see about that balancer.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
T
Vibrating clutch pedal
  • t.hite10
  • Aug 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2026
squeak93
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
