87 GT 5.0 HO, 5 speed, MAF converted - after about 2-5 min of driving it will start to backfire through the intake, buck, and stumble. If I floor it, she fires off, and goes well. once it's warmed up a bit (with barely any indication above 130 on temp.) it will be ok, unless I am going up a hill/ heavier load in 5th, then it lacks power and stumbles and pops again. once on a level plane again its ok. messed with timing, spout out! - 10, ok, 14 is better, but still does it. I am currently running low oct. gas, and have pulled timing back to 11, or 12. TPS appears to be operating properly and within range. - set to .862 (yes I have a fluke.)
codes - 82, and 85. canister is out. not noticing any vacuum leaks. it does hunt for idle within 150rpms or so of 1000. the passenger side of the firewall where all the solenoids and vacuum mess is seems a bit garbled by PO, but from what I can see it looks to all be sealed.
it runs great, and goes well when it is not doing this condition, be it cruising or running through the gears! its almost like a switch the way it comes and goes.
when trying to accelerate normally while its acting up - it sounds and feels like I can feel every piston hit, and you can hear distinct deep da-da-da-da-da-da-da of an exhaust note as it slowly accelerates, instead of the smooth bwaaaaaaaaa.......
only running catless X pipe, MAF conversion, and smog delete.
