  • SN95 4.6L Mustang Tech
Shift Kit VS. ShiftPlus Help ASAP
  • Thread starter Thread starter Lynx331
  • Start date Start date Apr 24, 2004
L
Lynx331
308
Chicago IL
Apr 24, 2004
  • Apr 24, 2004
Hey, my buddy just installed a B&M shift Improver Kit for his 92 camaro. We finally got it all in and took it out, and wow... that is awesome! lol
So i was thinking of getting one for my '97 V-6. ( i was going to post this on the v-6 forums but i postesed something like it before and got like one response so yea hopefully i'll get better feedback here ) So i was looking on jegs.com at the shift improver kits. I looked at the B&M ShiftPlus Electronic Shift Improver, its supposed to be really easily installed, but im not sure if its gonig to give as hard of shifts as a normal shift kit would. Anybody in here tryed it? http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3222&prmenbr=361 theres the link if anyone wants to check it out. But do you guys thinkg that electronic shiftplus would actually give my car a really hard shift? or should i just go with a normal shift kit? Thanks for any replies.
blewbyU
17
  • Apr 24, 2004
I'd say go with the B&M electronic shift its only 40 bucks and simple to install . Its going to increase your line pressure and make your shifts firmer but wont put you back in your seat.(how radical do you want to get with a v-6 anyway )
Bone Racing
1,075
Long Island, NY
Apr 24, 2004
  • Apr 24, 2004
the b-m is easy to install...i did it on my 98gt
but it increases line pressure...not safe in the long term on stock lines
blewbyU
17
  • Apr 24, 2004
I really dont think line pressurre will be that big of an issue anyway if you get concerned just flip the switch back to normal. Most valve-body kits increase line pressurre anyway.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 24, 2004
  • Apr 24, 2004
i say go with a transgo kit
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Apr 24, 2004
  • Apr 24, 2004
If you want a shift kit, the Jerry mod is the only one I recommend. It was designed by Jerry Wroblewski, an ex-Ford engineer who helped design the 4r70w automatic transmission. He wrote a series of articles over a www.tccoa.com about the 4r70w automatic transmission. His shift kit involves modifying the 1-2 and 2-3 accumulator pistons along with enlarging the holes in the seperator plate of the main control unit, aka the valve body. If you dont know how to do this, print out the instructions over at www.tccoa.com and give them to a transmission specialist. They'll know how to handle it. I dont recommend doing anything that involves manipulation of the EPC(Electronic control solenoid) as this will increase line pressure, but can result in premature failure of transmission components. I also dont recommend using any shift kit that involves "blocker rings" in the accumulator pistons. If youre going to mess with the line pressure, make sure you know what you're doing. Too much line pressure in the transmission in one area can result in reduced line pressure feed to other areas and can result in premature failure of those components. Basically put, read the articles over at www.tccoa.com and if you wish to get ahold of Jerry himself, go to www.modulardepot.com and join their forums board. Jerry is a memeber there and he now works for Superchips tuning. His user name over there is "SCT Guy". I hope this helps.
L
Lynx331
308
Chicago IL
Apr 24, 2004
  • Apr 24, 2004
I want my v-6 to hit as hard as i can make it hit, cuz it just "slides" into gear right now. So i want to try and make it hit as hard as i can make it ( without jepordizing my trans ) The reason i was looking at the electronic one is because of the switch, where i can change it any time i want, and with a shift kit its there if u want it or not. Anybody know if that electronic shift kit will really make a difference?
Islander03GT
470
Simi Valley, Ca
Apr 24, 2004
  • Apr 24, 2004
Dont mess around with the ShiftPlus. I had one on my 95 S10, and it doesnt do crap. Its basically a "tricker box" that makes your transmission shift as if it were at WOT all the time. So when you're flooring it, it doesnt do jack. Save up, get a real B&M or Transgo kit, and a trans cooler.
L
Lynx331
308
Chicago IL
Apr 24, 2004
  • Apr 24, 2004
so this isn't really all that good then? cuz it was either this, or the b&m shift kit that i was going to get....
Islander03GT
470
Simi Valley, Ca
Apr 24, 2004
#10
  • Apr 24, 2004
  • #10
its not worth the 35 bucks. hell, if you really want to try it, i can give you a link to build one for 2 bucks at radio shack. Its simply a resistor.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Brakes 1979-1986 Fox Parking Brake Adjustment
  • LiquidStangs
  • Sep 22, 2019
10K
Fox 5.0 Mustang Tech Sep 23, 2019
LX Dave
Car put me down......again. What now?
  • Wayne Waldrep
  • Sep 10, 2019
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2023
Mindseye007
T
Time To Ask For Help
  • TheDHndrsn
  • Mar 24, 2016
2K
SN95 4.6L Mustang Tech Apr 1, 2016
TheDHndrsn
T
C4 Shift Improver Kit Question
  • Markus
  • Aug 30, 2014
Classic Mustang Specific Tech Aug 31, 2014
rbohm
