SHIFT KIT...
  • Thread starter Thread starter 6FIVE_STANG
  • Start date Start date Sep 22, 2006
6FIVE_STANG
142
San Jose, CA
Sep 22, 2006
  • Sep 22, 2006
i want to get a shift kit fo my 1965 289 c4. where can i get one? what do i need?...
Cupid
162
  • Sep 22, 2006
Should be able to get one from Summit. I used one from TCI(a different tranny). It was pretty straight forward for me. Standard tools and patience is all I needed. Are you doing it on the car or off the car?
T
truck90278
382
Redondo Beach, CA
Sep 23, 2006
  • Sep 23, 2006
Also check with B&M. Another source is Performance Transmission, they make a lot of specialty items, including conversion parts for adapting an AOD
6FIVE_STANG
142
San Jose, CA
Sep 23, 2006
  • Sep 23, 2006
WELL I KNOW SOMEBADY THAT CAN DO ALL MY WORK CHEAP! but what parts do i need to buy??
zookeeper
3,415
63
109
Rogue River, Oregon
Sep 23, 2006
  • Sep 23, 2006
The last time I did one, the B&M shift improver kit came with everything except trans fluid. Pick up about 6 quarts of type F fluid, a couple cans of brake cleaner for cleanup and maybe some gasket sealer. Pretty much all there is to the install is dropping the trans pan, removing the bolts holding the valve body in, then follow the instructions, take out the parts they tell you to, install the parts they tell you to and drill the hole where they tell you to. Most kits come with varying stages, I use the street/strip one which firms up the shifts without becoming harsh.
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
