The last time I did one, the B&M shift improver kit came with everything except trans fluid. Pick up about 6 quarts of type F fluid, a couple cans of brake cleaner for cleanup and maybe some gasket sealer. Pretty much all there is to the install is dropping the trans pan, removing the bolts holding the valve body in, then follow the instructions, take out the parts they tell you to, install the parts they tell you to and drill the hole where they tell you to. Most kits come with varying stages, I use the street/strip one which firms up the shifts without becoming harsh.
