I am going to purchase a shift kit for my '98 auto. Which one should I go with? and where do I get the best price? Any pros/cons?
nyuk98gt said:Blev:
The Jerry mod just has you make a few holes larger in the separator plate. No holes are drilled in the valve body. The TransGo kit has you enlarge some holes in the separator plate AND change some valves and springs in the valve body, drill a hole in the valve body, and add some "stoppers" in the accumulator pistons. FWIW, I have a new, untouched TransGo kit sitting in my basement. Others have installed a TransGo kit in their cars and are completely satisfied. The J-mod is simpler and was 'invented' by a former Ford transmission engineer who helped design the 4R70W. I highly recommend the J-mod.
"Transmissions 101" in the Tech Articles\Transmissions section of TCCoA.com and the two "how-to" articles written by A-Train will tell you everything you need to know. (Please ignore the article on Shift Kits -- it is out of date/pre-dates the J-mod).
The J-mod is not difficult but you have to plan the job out (read, re-read, and read Chapters 13 and 14) and keep everything clean. You need a quality 'inch-pound' torque wrench, too, but you should have one anyway if you plan on working on your car! You will be tickled (a) with the results and (b) because you did it yourself.
