I installed my Autometer shift light tonight, and it isn't working.
I ran the green through the firewall and hooked it to the negative side of my coil. I tapped the red wire into an ignition hot wire in the drivers side kick panel, and I ran the ground to one of the steering column bolts. I know that spot is a good enough ground for a test light, but I am wondering if it is not a good ground for the shift light. I tested power to the light and it is showing power with a test light, so I am pretty sure it isn't a power issue. I know the wire going to the coil is on the negative side, so I don't think it is that. I am wondering if I chose a bad spot for the ground.
The light comes on for a second when I start the car up, but it will not work with the 5000 pill I have installed. I reved the motor up to around 5500 and the light never came on.
It is an Autometer light but I am using MDS pills because I was told they will work.
I do have an MDS 6AL, but it is mounted just above the cannister on the pass side, near the front of the car. I didn't feel like running a wire that far. The coil was a straight shot.
Any thoughts before I tear this apart again?
I out-cute myself all the time.
