Shift Light Hookup
  • Thread starter Thread starter JD1964
  • Start date Start date Oct 31, 2015
JD1964
there is enough sticking out to grab on to
3,643
1,660
194
Maryland
Oct 31, 2015
  • Oct 31, 2015
Is there a tach wire at the diagnostic connector?
I know I can tap in at the coil but I rather stay away from there if at all possible and make a connection closer to the dash via diagnostic connector.
Boosted92LX
5,721
4,244
224
Oct 31, 2015
  • Oct 31, 2015
I have to say.. I've been searching myself for 45 minutes and it's surprising how difficult it is to find a good wiring schematic that includes what you are looking for. Somewhere I have an old hard copy chilton book with complete schematics but dang if I can find it either.. ugh! Sorry bud. That's usually when I hit the ol' Stangnet easy button: @jrichker
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 31, 2015
  • Oct 31, 2015
There isn't a tach or shift light pickup in the diagnostic connector.
The instrument panel does have the feed for the stock tach, it is a AC pulse that varies in frequency and voltage. The peak voltage is from 10-15 volts. The voltage is not what the tach or shift light uses for information on what to display, it is the frequency that controls what you see on the indicator.
Before using this as a connection point check with the shift light manufacturer. They may need to connect to the TFI side of the ignition coil to work properly.
See http://www.stangnet.com/tech/cluster87-93.pdf for information on the wiring differences, The clusters are interchangeable, but you have to do some trimming & move some wires.
You will need the Adobe Acrobat viewer which is also a free download – Adobe Acrobat Reader DC Install for all versions
Reactions: JD1964 and Boosted92LX
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
Computer repair advise
  • sammie9271
  • Jul 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2025
Parauno
P
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
