shift points for stock cam???
  • Thread starter Thread starter Foxfan88
  • Start date Start date Jan 4, 2006
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jan 4, 2006
  • Jan 4, 2006
whats the best rpm to shift on the stock cam???
do i shift at this same rpm in every gear or do i shift at other points in other gears??
TomCat
412
Utah
Jan 4, 2006
  • Jan 4, 2006
5200 is what I've heard on the stock setup... I try to shift a little higher because of my cam.
TrunkFunk
Banned
Dec 28, 2005
83
A1A - Beach Front Avenue ...
Jan 4, 2006
  • Jan 4, 2006
A lot of it is feeling derived from just driving the car. If you are numb to the world around you it may be a bit more involved. Knowing the mannerisms of your car is more helpful than internet racers throwing figures out.
If you want a figure, how about 5200-5500 depending on which gear. The drop between each gear is not the same either.
Get to know your car.
Where were you shifting when you beat that Cobra?
onefstsnake
792
Northern VA
Jan 4, 2006
  • Jan 4, 2006
Well if you can find a stock 5.0 Dyno sheet then shift when the power drops off.
The shop I take my car to says that a stock 5.0's power drops off before 5K.
I usually shift at 4800. After 5K the valves start to float...
I
IntenseBlue
946
  • Jan 4, 2006
How do you know the valves float?
timewarped1972
642
mesa, az
Jan 4, 2006
  • Jan 4, 2006
the power falls totally flat when they start to float........and the rpms decrease somewhat...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 4, 2006
  • Jan 4, 2006
Try these as a starting point -- let your et's guide your adjustments.
1-2 shift - 5000 rpm
2-3 shift - 4800 rpm
3-4 shift - 4600 rpm
Those should let the car drop back to right around the torque peak with each successive shift. Your quickest acceleration times should come if you can keep the car in the meat of the torque/HP curves.
onefstsnake
792
Northern VA
Jan 4, 2006
  • Jan 4, 2006
It happens alot on older engines. The springs are old and cant close the valves quick enough at higher RPM.
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jan 5, 2006
  • Jan 5, 2006
so after each shift i want the rpms to land right around 3k? (torque peak)
and when i raced the cobra, i just shifted around 5k each time, only got to 3rd gear though....
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jan 5, 2006
#10
  • Jan 5, 2006
  • #10
My stock motor I would shift at 5200 on an aftermarket tach (stock tachs are usually off some) and it got me decent times...
But like stated before, you have to know your car and where it likes to be shifted! Some cars its higher some lower (also with all the tachs being off different amounts, who knows where your actually pulling the gear)!
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 5, 2006
#11
  • Jan 5, 2006
  • #11
Foxfan - a set of dyno curves are really helpful -- you'll clearly see at what rpm the torque/HP to the wheels peak at. Armed with that, and your tranny gear ratios you can calculate what rpm you'll fall back to with each shift. You don't want to hold to far PAST the power peak in a gear, and you don't want to fall to far below the torque peak with each upshift. I suspect your torque peak occurs a bit higher than 3000. However, if it does actually occur at 3000, then your power peak is probably in the low 4000 range somewhere, and shifting even lower than I suggested may result in quicker times.
The old C4 Corvettes (mid 80's LT1) were shifted around 4400 rpm to achieve quickest lap times in road racing. Other than making noise, there was simply no reason to rev them any higher even though you could spin them up past 5000 in the lower gears -- it just resulted in going slower because you were well past the engine's power peak.
If you're serious about optimizing shift points, spend $50-70 for a dyno day and see what your actual torque/power peaks occur at rpm-wise. As mentioned above, a tach that matches up with the dyno tach helps too....
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jan 5, 2006
#12
  • Jan 5, 2006
  • #12
Keep in mind too the shape of the curves has an impact on all this. If the curves are real 'peaky' then shifting too high or too low has a bigger impact on acceleration rate compared to what happens with relatively flat curves.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jan 5, 2006
#13
  • Jan 5, 2006
  • #13
Your best bet. Go to the track with a notebook...
Change only the shift RPM, and see what was affected (where in the pass did it improve or was it hurt). This is the only real way to see what your car likes.
ninety1gt
162
san antonio
Jan 5, 2006
#14
  • Jan 5, 2006
  • #14
ur 1.7 rr's have alot to do with it, should have, gotten new springs
onefstsnake
792
Northern VA
Jan 5, 2006
#15
  • Jan 5, 2006
  • #15
Yeah springs are pretty cheap.
Although the keepers are a PITA...
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Jan 5, 2006
#16
  • Jan 5, 2006
  • #16
4500.. thats as high as i run it.. ive run it to 5500 and it made no difference in ET's except for .1 of a difference
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jan 5, 2006
#17
  • Jan 5, 2006
  • #17
Care to share the ETs you speak of???
My dads car with a stock cam (4 degrees retarded) went from 12.4s to 12.1s merely by going from 5500 shift points, to 6000 RPM! Granted his isnt like the cars mentioned here, but the right shift point for a car can be a huge improvement!
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
