  • 1994 - 1995 Specific Tech
Shift quicker
  • Thread starter Thread starter Gumby84
  • Start date Start date May 5, 2009
G
Gumby84
24
IN
May 5, 2009
  • May 5, 2009
i was wondering if there was a way to make my AODE shift quicker? it seems to take longer then say a 4l60 in a camaro. this is my first ford so i am not sure if it is normal for this type of trans. also if a shift kit will say help or fix this problem will it shift so hard that it blows up or makes it undriveable during normal driving?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
May 5, 2009
  • May 5, 2009
You can get a TransPak from B&M or something like that. It will make it shift quicker, and actually reduce the wear in the transmission.
Kurt
toyman
1,944
54
79
Vernon BC
May 5, 2009
  • May 5, 2009
I'm using a Transgo HD2 shift kit. Shift firmness is adjustable. Nothing will "blow up".
HISSIN50
34
129
May 6, 2009
  • May 6, 2009
Look into J-modding the trans.
SN95StangMan
1,292
Lynwood, CA
May 6, 2009
  • May 6, 2009
TCCoA Tech Articles
Read the article on "modifying the valve body to jerry's specifications"
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 6, 2009
  • May 6, 2009
Instal an external trans cooler no matter what you do!
Dino Dino Bambino
1,672
89
79
Cyprus
May 6, 2009
  • May 6, 2009
Same here. I love it.
Gearbanger 101 said:
Install an external trans cooler no matter what you do!
Definitely a good eye deer for any auto tranny.
Dan95-5.0
1,110
Manitoba, Canada
May 6, 2009
  • May 6, 2009
either j-mod it or go the Transgo route. tranny cooler is a must even if its a stock tranny. i went a step further and added a deeper pan and trans temp gauge.
my trans shifts firm and quick now. it also chirps the tires when i feel like it
G
Gumby84
24
IN
May 6, 2009
  • May 6, 2009
DAN 5.0 your transgo shift kit allows you to drive normal and chips when you hammer down. do shift kits help trans life or reduce?
SN95StangMan
1,292
Lynwood, CA
May 6, 2009
#10
  • May 6, 2009
  • #10
The harder shifts will actually increase the life of the tranny. Quicker shifts = less wear on the clutches
Dan95-5.0
1,110
Manitoba, Canada
May 7, 2009
#11
  • May 7, 2009
  • #11
the transgo kit increases the line pressure and like SN95stangman said, increased clutch life. those very slow delayed shifts kills the clutches.
normal soft acceleration and the shifts are nice and tight and instant. with more throttle 1-2 chirps really nice.
Dino Dino Bambino
1,672
89
79
Cyprus
May 7, 2009
#12
  • May 7, 2009
  • #12
True but they can shock load the rest of the drivetrain and increase the risk of failure elsewhere.
toyman
1,944
54
79
Vernon BC
May 7, 2009
#13
  • May 7, 2009
  • #13
The OP didn't indicate the extent of his mods if any. I wouldn't be overly concerned with a stock engine but you're correct it does put stress elsewhere. With my mods I expect to snap an axle one day.
D
AOD with 4R70W Internals and a Shift Kit - 1 to 2 Shift Question
  • Davjake128
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
Davjake128
D
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
