Drivetrain Shift Select
  • Thread starter Thread starter Sleepy-D
  • Start date Start date Oct 19, 2016
Sleepy-D
  • Oct 19, 2016
I just acquired my first fox. It's anot 89 gt auto. The current issue on the chopping block is this shifting problem. When selecting park with the selector, the car stays in a forward gear, however the park anti-roll away catch is engaged. Not a familiar area for me, just thought I would get some input, before climbing under the car
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 19, 2016
  • Oct 19, 2016
I assume the transmission actually shifts? Will the shifter go easily through all the gears and does the indicator move at all? Does the shifter lock out before you move into R or P by needing to hold the button on the shifter?
Sleepy-D
  • Oct 19, 2016
It seems to be all functioning properly inside the cab (shifter, neutral ss, and button lock). Not too sure about the indicator. But I can push the button and shift to R it tries lunge forward. Shift back to park and it goes nowhere. Neutral Rev in park and it's revs to around 2100rpm but seems to be in a bind. It doesn't hit the limiter as it should, shares more characteristics having parking brake engaged when you try to take off. That brought me to think the trans is in a forward gear (I believe to be second).
stykthyn
5,232
2,652
223
gainesville
Oct 19, 2016
  • Oct 19, 2016
Sounds like you need a new shifter cable
billison
I like tinted tail
2,607
1,094
184
stl
Oct 19, 2016
  • Oct 19, 2016
Will it roll in neutral ?
Sleepy-D
  • Oct 24, 2016
Got look a little closer at the problem, linkage is fully functional shifter is functioning properly. With the linkage disconnected from the transmission, the gear selector on the transmission catches in all positions as it should. I'm thinking the transition is shot and was in gear when it went out, but I don't know
General karthief
Mod Dude
Aug 25, 2016
28,113
10,729
213
polk county florida
Oct 24, 2016
  • Oct 24, 2016
maybe, someone asked if it will roll when trans is shifted to neutral? Try it with the engine off first, then with the engine running, just be careful, don't want to be chasing it down the street.
Sleepy-D
  • Oct 24, 2016
I made the mistake of nosing it up to the shed on a hill and in all shifter positions it tries to lunge forward. Fluid is over full (cold not running) and looks to be full of glitter (metal shavings). I have a sn95 that I can swap trannys with. Are they the same length?
General karthief
Mod Dude
Aug 25, 2016
28,113
10,729
213
polk county florida
Oct 25, 2016
  • Oct 25, 2016
Fluid level cold, engine not running is useless. Glitter in the oil anytime means tranny is in trouble. Don't know about the sn95, I think it maybe longer, if you can, get yours rebuilt.
Don't bother changing the oil, rebuilt or replace.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
O
My rebirth, Hi from PA
  • onemore1987
  • Jun 28, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 29, 2026
onemore1987
O
