Shifter Boot To Bezel Attachment
  • Thread starter Thread starter KFRG
  • Start date Start date Jun 9, 2009
K
KFRG
41
  • Jun 9, 2009
Hey guys,
Whats the best way to attach a shifter boot to the console bezel? The boot did not come with holes pre-stamped.
Thanks.
Saleen0679
876
24
49
Yakima, WA
Jun 9, 2009
  • Jun 9, 2009
You should be able to use the little posts on the bottom of the bezel or the old boot as a pattern to punch holes in the new boot then slide the clips over the posts.
K
KFRG
41
  • Jun 9, 2009
Thanks Saleen, so the bezel posts do slide through the boot into the console.
Saleen0679
876
24
49
Yakima, WA
Jun 9, 2009
  • Jun 9, 2009
The bezel posts slide through the boot, but they don't go into the console. There are some small rectangular clips (also called flat nuts) that slide on after the boot that keep the boot fastened to the bezel.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jun 10, 2009
  • Jun 10, 2009
There are two sets of clips on the bottom of the bezel. There are small ones that the boot is supposed to be attached to. These are located nearest the hole where the boot goes through. The mounting tabs located around the outside of the bezel the boot does not touch.
Personally I just removed the original boot mounting tabs, pulled mine through and used heavy duty tape. You will never see the tape, and if you want it to be slightly more sealed up, toss some adhesive on there as well.
Sounds ghetto rigged, but works perfect, looks perfect, and saved me time and energy.
K
KFRG
41
  • Jun 10, 2009
Thanks guys. I only remember seeing the mounting tabs on the outside of the bezel, not the smaller ones for the boot. Both the bezel and boot are from 5.0 resto.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jun 10, 2009
  • Jun 10, 2009
The aftermarket bezels might not have them... I lie the adhere/tape idea.
For Sale Center console delete parts
  • 86_5-OH
  • Aug 31, 2025
  • Interior Exterior Parts
Interior Exterior Parts Oct 16, 2025
NessMeraz
N
For Sale 79-86 center console delete shifter bezel
  • 86_5-OH
  • Aug 11, 2025
Interior Exterior Parts Nov 20, 2025
5ptslow
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
K
Console Heat after MGW shifter install
  • KirkACola
  • Sep 24, 2025
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Sep 24, 2025
