  • SN95 4.6L Mustang Tech
shifter hitting console???why
  • Thread starter Thread starter yellowtang435
  • Start date Start date Aug 23, 2005
Y
yellowtang435
73
Franklin County, VA
Aug 23, 2005
  • Aug 23, 2005
for some reason my shifter hits my center console. i had to remove the little bezal around it so it didnt break it, and i took my tri-ax shift handle off and put the stock one back on an it still hits. doe anyone know what might be causeing this. i dont want to have to take it into the dealership
Redfire03GT
395
Newark, CA.
Aug 23, 2005
  • Aug 23, 2005
Sounds like at some point you had thrown the shifter too far forward. You may have damaged somethinb but I doubt it. Do you still have the stock shifter or do you have a Tri-Ax? If you have the stock shifter, ditch that POS and get a real one. If you have a Tri-Ax and managed to do that, then you have more problems than that.
hotdog71
427
Seattle, Eastside
Aug 24, 2005
  • Aug 24, 2005
not sure if this is any help but did the spot bolt come out? I am not sure if it had fallen out if you would have that issue though, just an idea.
bigorangegt
20
south florida
Aug 24, 2005
  • Aug 24, 2005
that happen to me once. the shifter handle was on backwards.
KronicRacer
502
puttering around Ft Lauderdale, FL
Aug 24, 2005
  • Aug 24, 2005
+1 for the aftermarket shifta!
T
Torinalth
952
Clayton NC
Aug 24, 2005
  • Aug 24, 2005
what year car? if it has the 3650 there is no way that can happen unles the tranny its self broke. the tremec has internal bumpstops and eliminate all chance of this.
if you are the earlier T45 then it is possible to overthrow it.... however, you mentioned a tri ax handle... so i assume you have the whole shifter. that being the case the shifter has stop bolts that keep it from going too far. when i had the triax there was a solid 2 inches from the handle to the dash... and now that i have my comfort pro handle its just nowhere near.
as stated earlier, you do have the handle setup so that it is closer to you, correct? and at the lower position? you may want to uninstall the shifter, check out everything, then reinstall to make sure something it not blatently evident of a problem. I just dont see it as being possible, at least on a 2001.5+ with a triax...
Torinalth
BlueRuckus
204
Miami, FL
Aug 24, 2005
  • Aug 24, 2005
IF you are using an aftermarket shifter (not just the handle), then I second the motion to check the bump stop screws on the shifter assembly. You should be able to see these by removeing the plastice console and the rubber boot/plate.
But, if you do not have an aftermarket shifter, by all means, get one!
You'll love the feel! I can't speak for any other brands, but I think the Steeda Tri-Ax is great. IMHO.
Good luck.
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Hurst comp 5sp Shifter springs Help
  • R82148V
  • Jan 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 15, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
H
Transmission Help
  • Harman78
  • Feb 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 21, 2025
Harman78
H
