Shifter Install
I ended up removing the whole center console. The back bolts holding the lower boot on were a tight reach.
x2
Be careful of the clips that hold the shifter boot to the floor. Mine were rusted and most of them just sheared off when I took the old shifter assembly out. Be gentle if you take the console out, it will break easily.
Not sure what you mean by the "back square" of the shifter. There's no need to remove the center console, I have pretty big hands and although it was a bitch, I got it done. Proper tools are key.
Pull the shift knob
The plastic boot trim piece just snaps out
Take out the 4 screws for the lower boot. 2 rear, 2 front (bitch!)
Pull the 4 shifter bolts, and remove the shifter.
Clean the sealing surfaces really well, apply a layer of black rtv, and let it tack up for a couple minutes.
Install the new shifter with the 4 bolts, making sure the ball engages with the socket in the tranny.
Install the handle if not done so already.
Set your shift stops! Put the tranny in 3rd gear and turn the stop in until it ALMOST touches the shifter. You want a tiny gap between the stop and shifter. You don't want it to touch the shifter and possibly prevent it from going all the way into gear, but if you push forward on the shifter with a little force, you want it to hit the stop. Do the same in 4th gear, then make sure the stops look good for all gears.
Install your lower boot. The front bolts are going to be even worse this time around. Just face it, your hands will be bleeding, and you will be swearing, but you'll finger it out.
Snap in the upper boot
Screw on your shift knob
