I Am New To This Board And Just Had A Couple Questions. I Just Bought A 92 Mustang Gt With An Auto Trans. The Problems Are, The Shifter Is Sloppy And Won't Click Into Each Gear, The Car Won't Start Unless You Pull The Shifter Into Reverse. And The Nuetral Safety Switch Is Good. And Then, After The Car Starts You Can Put It Into Park But Then The Reverse Lights Stay On.
What I Am Wondering Is If The Shifting Mechanism Is Bad Or Does The Cable Need To Be Adjusted? Any Help Would Be Great!
Thanks In Advance.
Thanks In Advance.
