  • 2005 - 2009 Specific Tech
Shifter Question
  • Thread starter Thread starter halox07
  • Start date Start date Jun 11, 2009
halox07
  • Jun 11, 2009
I just bought an 05 GT that was an older man's toy. He put a bunch of nice parts on it, and one of those was a Steeda Tri-Ax shifter (looks like a Tri-ax anyways). My issue is that I think something is wrong with it.
First off, the throw is pretty long. As long as my 02 GT's stock shifter.
Second and most troubling is that the stick still moves left to right while it's in gear. The first time I started the car for a test drive I stalled the car because it was in gear. I rocked the stick 2"s while in gear and thought it was in neutral. It has an incredible sound while shifting, very mechanical. It shifts properly, but the stick is just so loose that I can't imagine why it would be like this.
With the 02 I could see exactly where the shifter connects inside the transmission. I'm not sure how the 05 works, so I can't even begin to figure out if it's an adjustment, or there is something wrong with the installation/stick itself...
Any help would be greatly appreciated.
gashog
139
Fresno, CA
Jun 12, 2009
  • Jun 12, 2009
Sounds like something isn't installed correctly. Put the car on ramps or stands and look under the tunnel. There is only a couple places it could be loose. Also pull the boot off at the top and look there first if you haven't done that already and see if top portion is screwed down correctly also (takes torx i believe).
I have the steeda and it doesn't wobble side to side when it's in gear.
halox07
  • Jun 12, 2009
Thank you, sir.
Steel Horse
Altoona, IA
Jun 12, 2009
  • Jun 12, 2009
Have you found out for sure what shifter is installed? Just curious is all.
halox07
  • Jun 12, 2009
I'm certain it's a tri-ax, unless it's an extremely accurate replica. The body and 2 level stick are identical to the tri-ax.
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
