shifting problem
  • Thread starter Thread starter jeffs89gt
  • Start date Start date Jul 27, 2005
J
jeffs89gt
83
  • Jul 27, 2005
when i shift it seems like its harder to put into gear than it should be. i drove my friends 92lx and it shifts alot smoother than mine does. it doesnt grind, its just stiff and hard to put in gear. sometimes after i drive it for awhile i cant put it back into first, or other gears. its random and i cant figure it out. sometimes it goes into gear like it should, and other times it fells like im trying to put it into a gear thats just not there. reving it up sometimes works. it never grinds tho.... thats what confuses me. if it was a bent fork wouldnt it be hard all the time. when teh car cools down im gona check the fluid level.... can anyone help me. o and if i go to downshift from 5th to 4th it wont go in without reving it up to like 3 grand, but it never grinds
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 27, 2005
  • Jul 27, 2005
Id love to see the reply, as my 4cyl does this, sometimes it slides in perfect others it is almost impossible to get into gear!
J
jeffs89gt
83
  • Jul 27, 2005
i just checked the level in the tranny. i pulled hte top plug out and the fluid was barly coming out. the car was run for about 25 min b4 i put it in the garage, and its sat for about 40 min.....
J
jeffs89gt
83
  • Jul 27, 2005
someone has told me it is the clutch draging and i need to replace the clutch? is that true
E
executioner
30
mass.
Jul 28, 2005
  • Jul 28, 2005
almost sounds like the synchros. i,m not an expert but i do drive nonsynchro 13 and 15sp class a trucks. you said you have to rev it up to go from 5th to 4th. thats the way you drive non synchro trannys. have to let the rpms drop(about 500 rpm) to upshift. have to rev them up(about 500rpm) to grab the next gear downshifting.
90 7up vert
Black Sun 5.0
1,337
L.I., N.Y.
Jul 28, 2005
  • Jul 28, 2005
My shifter got so bad that I actually hurt my arm last night trying to get it into gear. Dropped it off at the shop, the initial thought is the clutch quadrant.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
