  • SN95 4.6L Mustang Tech
shifting
  • Thread starter Thread starter COBHClambofgod
  • Start date Start date Dec 8, 2008
C
COBHClambofgod
  • Dec 8, 2008
ok so here's the deal, my friends and i decided to go out and race from a stop, i own a 99 gt 5 speed all stock, he has a 99 gt auto with an h pipe, cold air intake, and flowmasters, off the line we were neck and neck through first and second but he started pulling on me after that and beat me. now i have a few questions,
whats the best rpm to shift at when racing from a stop?
whats the best rpm to launch from at a stop?
will these numbers change if i get gears?
and what will those numbers be?
thanks in advance, i know i sound stupid but i know the people from these forums know what they're talking about.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 8, 2008
  • Dec 8, 2008
You race from a stop at the track no matter what. Why include that in your question? No street racing or you get the lock. hint hint
First of all...the h-pipe will give him a slight advantage.
A total stock GT I'd shift at 5500. Depending on tires your launch can be upwards of 4500. Find a place to practice the best launch without breaking the tires loose. Sounds like you are OK on the launch if you are neck and neck through second.
Gears won't change the shift points...just how quickly you get to them. I raced my friends 97 and I was shifting into 3rd when he was in the middle of 2nd. I have 4.10's to his 3.27's.
C
COBHClambofgod
  • Dec 8, 2008
thanks
one more question i'm asking for 3.73's for christmas that will give me a good advantage over him right?
F
ForPointSex
395
Mercer, NJ
Dec 8, 2008
  • Dec 8, 2008
I get the best result when I shift at 5,500rpm.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 9, 2008
  • Dec 9, 2008
It should...you are into the power band quicker. Just need the practice becasue the bigger the gear the easier it is tio break the tires loose.
squeak93
2,348
417
164
Joplin, Missouri
Dec 9, 2008
  • Dec 9, 2008
Driver mod.....
A auto should not beat a 5 speed with a good driver. I had an 04 stock 5 speed with a buddys full bolt on auto, we raced many times and I always won. He even had 305/315 tires out back and had the advantage there. He would get me out of the hole by about 1/2 a car, then i would run him down and put a few legnths on him. (think it was more him leaving a bit ealier than being faster, I always wait for the other guy to move when racing on a closed course).
You don't launch a car on street tires, best bet is to take off at idle or at no more than 1k. I found it best to just have my foot on the throttle barely above idle so I wounldn't punch it too hard and start the tire burning freenzy. Take off pretty soft, get going then hammer down, takes some finesse(sp) and practice but I was able to pull 1.9's on 4.30 gears and sumitomo htrz 1's. It can be done and u should not be beat by a bolt on auto... now an auto that has a built trans and a stall with sticky's, watch out.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
