We're doing a clutch job on an 89 LX with stock T5. We ordered the steel throwout bearing retainer collar from Summit thinking it was a good thing to do while at it. Problem is, the stock shim is too tight and no shim is too loose. All the local Ford place has is the stock shim and the local speed shops are no help. Has anybody solved this problem and if so, where did you get the proper shims ? What is the general feeling on this replacement collar, is it that much of an improvement ? We may have to slap the old collar back on to get the car back together. A search turned up nothing.
