  • SN95 V6 Mustang Tech
SHO v-6?
  • Thread starter Thread starter Sims6986
  • Start date Start date Apr 30, 2004
Sims6986
50
Indy
Apr 30, 2004
  • Apr 30, 2004
Has anyone ever thought of putting the sho motor out of a taurus into a v-6 mustang? I think the results would be very impressive but i don't think they're are mounts available for this does anyone know?
C
cobra232
233
  • Apr 30, 2004
it would be waste of time. the 3.8 can be taken to far higher hp levels for far less than it would cost to do such a swap. the swap probably could be done if you used a tranny from a 4.0 2wd explorer but even then it would be a technical nightmare
mounts would be the least of the worries for such a swap
nomuffler
330
Awash in a sea of decedant luxury and meaningless
Apr 30, 2004
  • Apr 30, 2004
Seems kinda silly. f ou were gonna go that far, you might as well use a 300ZX engine. Or a supra engine. Putting a sideways engine N/S would be a huge pain, where'd you come up with this idea?
D
DanM
332
  • Apr 30, 2004
Would be very complicated as the SHO is a FWD car. You'd need to find some other transmission that would fit, right it up, etc. etc..
As pointed out, there's no point. The SHO motor was decent for its time, but not so much anymore. In fact MANY V6s nowadays make more power and more power-per-displacement than the SHO motor. 220hp isn't all that impressive for a 3+L motor anymore.
A split-port 3.8L would probably be just about as fast in the Mustang anyway. And with a bit of work, the 3.8L would pretty easily outperform the SHO motor anyway.
T
turboSHO
  • May 17, 2004
The Aerostar Bell housing matches up with out too much trouble. There are a number of RWD SHO powered cars out there.
My SHO (3.2) cranks out 520hp. How many 3.8's put out that kind of power?
Keep in mind, this is a 15 year old engine. Can't expect it to keep up forever, but it still holds its own. 73.3hp/L is still a respectable number. Nissan 3.5 VQ only puts down 81hp/L, and it is probably on of the highest specific output V6's out there right now.
stackz
1,352
james island, sc
May 17, 2004
  • May 17, 2004
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
