  • SN95 4.6L Mustang Tech
Shock question
  • Thread starter Thread starter wasi34
  • Start date Start date Jul 21, 2007
wasi34
  • Jul 21, 2007
I have a 2001 GT with just minor upgrades....K&N cold air intake and magnaflow exhaust. I recently had the car in the shop because of a check engine light which was caused by a vacuum hose leak.
While fixing the problem they told me the horizontal shocks are gone and need to be replaced. After reading other posts on this site they all talk about switching to lower control arms. Do I then have to change the shocks as well?
I am really looking for a whole kit that would replace it all (if they even make such a thing)?
Any thoughts?
Thanks,
Wasi
Mossberg
ATL, Shawty
Jul 21, 2007
  • Jul 21, 2007
Are you talking about the quad shocks? Some just run their cars without them.
Skud
493
Saskatchewan
Jul 21, 2007
  • Jul 21, 2007
I put on some Maximum Motorsports lower control arms and took off the quad shocks. No problems at all..
Riley
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jul 21, 2007
  • Jul 21, 2007
You should run the quad shocks even with control arms. I know there are guys here that will say they aren't needed with a control arm change. But some guys have still had wheel hop with them. They are not a band-aid item for sloppy bushings. If ford could have eliminated an expensive component by redesigning a cheap bushing, they would have.
For replacement quad shocks, Autozone has gabriel replacements for $25 each. They are listed online under "steering dampener"
wasi34
  • Jul 21, 2007
I have seen numerous times on different posts that people say you no longer need the quad shocks if you upgrade to control arms, while others say you still do. Not sure what to do.
I tried to look up the part at autozone and they said they did not have one for my make and model.
How hard is it to install control arms and how much would a good set cost? When doing that should I do the shocks at the same time?
Thanks.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jul 21, 2007
  • Jul 21, 2007
Which shocks? Just the quad shocks (the horizontal ones?)
Do you have wheel hop issues?? If not, then don't worry about it.
wasi34
  • Jul 21, 2007
I do not have any wheel hop at this point, so there is no need to change them I guess.
If I was to do a control arm setup what do you recommend and are they hard to install?
The Stang GT
81
  • Jul 21, 2007
wow, well I am actually upgrading my lac's. They are a bitch if you dont have like a real shop...As a drive way install which i am doing they are difficult but not impossible....And just keep the quad shock, cause if you were not suppose to have them, then ford would have never put them on.....
Scorcher2005
883
South Carolina
Jul 22, 2007
  • Jul 22, 2007
Thats like saying you dont need a supercharger because if you did, ford would have put one on.
Its all about personal preference. Take them off, if you still get hop, then put em back on.
TweekedGT
1,274
Alberta
Jul 22, 2007
#10
  • Jul 22, 2007
  • #10
If you've ever seen the difference between a stock arm and say a maximum motorsports piece you will understand why you can take the quads off when you change. The stock pieces are a real thin flat metal (I can't even call it steel cuase it so thin) bent to shape. The MM stuff is 1/4" thick round tube, it is not even close. I put my LCA's on about two months ago and took the quads off and have never had wheel hop. I run my car at the track almost every weekend. They are also quite easy to install as well, change your shocks at the same time if you are planning a shock change in the near future.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jul 22, 2007
#11
  • Jul 22, 2007
  • #11
That's not even the same comparison
Ford did put a supercharger on a Mustang. It was called the terminator. It cost $10K more than a regular GT.
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
  • Gulftown980x
  • Jul 29, 2026
squeak93
