  • SN95 4.6L Mustang Tech
shock/strut install pics
  • Thread starter Thread starter rai_281
  • Start date Start date May 4, 2006
R
rai_281
  • May 4, 2006
i have a 2003 gt and its lowered with h&r supersport springs. i just bought some bilstien shocks and struts and i wanted to install them myself. i was wondering if anyone can post some pics of the install or post a link where i can see some pics of the install process.
46gtsblown
278
  • May 4, 2006
Just remove and replace in the opposite order in which you removed the parts, it is pretty basic.
BTW don't forget to get an alignment when you are done.
Dwayne
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
May 4, 2006
  • May 4, 2006
sorry no pics but for the front make sure you put a jack under the A-arm so that the spring dosen't shoot out when swapping the strut or it can cause serious injury. As for the rears they are real easy to do.
nyuk98gt
1,427
Chesterfield, MO
May 8, 2006
  • May 8, 2006
rai_281:
You will not need the stock bump stop for the struts because Bilstein provides one. You won't need the stock dust cover for the struts because the new struts have a lovely blue accordian dust cover.
You will need PB Blaster (a high quality penetrating oil) and an impact wrench (electric will work OK) to get the lower strut bolts loose. "They are on there real good". You need to remove the brake caliper to get access to the lower strut bolts, too. Not a big deal but you need to be prepared.
The springs are held in pretty well unless you disconnect the tie-rod ends and the sway bar (but why would you do this?). Don't worry!
You have to remove the decorative lining in the trunk to expose the shock retaining nuts. Be careful because the trim is fiberglass and can break or crack. Don't force it, just work at getting it loose a little at a time.
Run a search here or at Corral.net for an installation article. I did this just a few months ago but I didn't think to take any pics (DOH!).
The Haynes manual ($20 at AutoZone, Borders, etc.) has pics and instructions. Worth the investment, imo.
HTH,
Chris
tomustang
Psychotic Member
3,434
McLean Hospital
May 8, 2006
  • May 8, 2006
Might aswell add "use an impact gun to remove/reinstall the top strut bolts, if you have one"
GDawg
1,469
Nevada
May 9, 2006
  • May 9, 2006
I replaced mine without having to use an impact gun. It would have been much easier if I had one but it wasn't that bad. Just need some old fashion muscle.
The stock struts have a groove for a flat head and the bilsteins have a hex slot for counter force.
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
